2nd gen 86 was just spotted today.
Renderings from BestCarWeb Japan from April 2020.
Wow the renderings actually got it right. That's pretty impressive.Some big news making the rounds today. GR86 spy shots. Where are the new Z spy shots?
Compared to the outgoing 86 model below, it doesn't seem that different especially if you factor in how the top most part of the passenger side window curves.I don't know if it's just the angle of the rendering but the cabin seems a bit too tall for me, that or the hood is a bit too small. Aside from that it looks just like the spy photo.
That's true, i guess it's the hood that's throwing me off then.Compared to the outgoing 86 model below, it doesn't seem that different especially if you factor in how the top most part of the passenger side window curves.
Possibly. Plus the outgoing 86 can seat many 6-6'5 ft tall drivers so I doubt Toyota is changing that area much. Some improvement to aerodynamics would have been nice via a sleeker roof. Too late here. maybe the 400z?That's true, i guess it's the hood that's throwing me off then.
Based on what's been revealed so far the 400Z should be much sleeker than the 86/BRZPossibly. Plus the outgoing 86 can seat many 6-6'5 ft tall drivers so I doubt Toyota is changing that area much. Some improvement to aerodynamics would have been nice via a sleeker roof. Too late here. maybe the 400z?
Vehicle | 2+2 sports car |
Engine | 4-cyl. horizontally opposed (Boxer), alloy cylinder block and cylinder heads |
Displacement | 2.4-liter |
Bore x stroke | 3.70 in. x 3.39 in (94mm x 86mm) |
Compression ratio | 13.5:1 |
Horsepower | 228 HP @ 7,000 RPM |
Torque | 184 lb.-ft. @ 3,700 RPM |
Fuel system | Toyota D-4S® direct fuel injection and port injection system |
Valvetrain | Double overhead chain-driven camshafts (DOHC), 4 valves per cylinder, dual Active Valve Control System (DAVCS) controls valve timing on intake and exhaust camshafts |
Transmission | Standard: 6-speed manual with short-throw shifter Optional: 6-speed automatic with steering wheel paddle shifters and downshift blipping control Limited-slip rear differential is standard for all. |
Stability/traction control | Vehicle Stability Control with traction control and five settings |
Suspension | 4-wheel independent Front: MacPherson-type struts, lower L-arms, coil springs, stabilizer bar Rear: Double wishbone, coil springs, stabilizer bar |
Wheels | 17-inch aluminum alloy on Premium 18-inch aluminum alloy on Limited |
Tires | 215/45 R17 87W Premium 215/40 R18 85Y Limited |
Brakes | 4-wheel ventilated disc |
Exterior Dimensions (in.) | |
Wheelbase | 101.4 (plus .02 inch) |
Length | 167.9 (plus 1.2 inch from last generation) |
Width | 69.9 inches |
Height | 51.6 inches (minus .04 inch from last generation) |
Curb weight (lbs.) | Estimated for U.S. model: 6-speed manual: Premium 2,815 lbs. Limited 2,835 Automatic Premium 2,864 lbs. Automatic Limited 2,881 lbs. |
