Here are some of the main specs for the 2020 Supra. If the rumors are to be believed the 400Z should have more power with its twin-turbo V6 than the Supra at the very least.
For the dimensions, hopefully there's a bit more cabin space in the 400Z because I hear it's very cramped in the Supra.
As far as specs go, how do you want the 400Z to stack up to the Supra?
Engine | 3.0 l I-6 |
Power | 335 hp @ 5,000 rpm (250 kW) |
Torque | 365 lb·ft @ 1,600 – 4,500 rpm (495 N·m) |
Induction | Turbocharged |
Fuel type | Premium |
Transmission | 8-speed automatic |
Drivetrain | RWD |
Steering | rack and pinion, electric assistance |
Turning diameter | 10 m (34′) |
Front suspension | independent, Macpherson strut |
Rear suspension | independent, multi-link |
Front brakes | Disc (ABS) |
Rear brakes | Disc (ABS) |
Front tires | P255/35YR19 |
Rear tires | P275/35YR19 |
Length | 4,381 mm (172″) |
Width | 1,854 mm (73″) |
Height | 1,294 mm (51″) |
Wheelbase | 2,470 mm (97″) |
Front track | 1,595 mm (63″) |
Rear track | 1,590 mm (63″) |
Weight | 1,541 kg (3,397 lb) |
