This Toyota patent filed back in 2020 shows a carbon fiber monocoque similar to what some exotic car companies already produce. It also shows how a mid-mounted electrified powertrain and battery could be mounted to it.
I don't know about you guys but this is starting to seem like plans for a next-gen MR2, especially after Toyota revealed an all-electric MR2-esque concept last last year.
Check out drawings from the patent titled "MONOCOQUE VEHICLE STRUCTURE" attached below.
Abstract
(EN)
Each of a monocoque body and a subframe is integrally formed of reinforced resin. The subframe has a bottom portion and an upstanding portion. The bottom portion is fixed to the lower portion of the rear wall of the monocoque body and extends rearward of the vehicle. The upstanding portion extends upward from the bottom portion. An engine is directly mounted on the rear surface of the upstanding portion.
Abstract
(EN) Each of a monocoque body (10) and a subframe (30) is integrally formed of reinforced resin. The subframe (30) has a bottom portion (32) and an upstanding portion (34). The bottom portion (32) is fixed to the lower portion of the rear wall (20) of the monocoque body (10) and extends rearward of the vehicle. The upstanding portion (34) extends upward from the bottom portion (32). An engine (70) is directly mounted on the rear surface of the upstanding portion (34).
Abstract
(EN)
PROBLEM TO BE SOLVED: To inhibit or prevent an increase in the weight and degradation of rigidity of a vehicle having a monocoque body made of a reinforcement material reinforced resin from occurring at a time of mounting an engine in the vehicle.
SOLUTION: A monocoque body 10 and a sub frame 30 are integrally molded and made of a reinforcement material reinforced resin. The sub frame 30 includes a bottom 32 and a standing part 34. The bottom 32 is fixed to a lower part of a rear wall 20 of the monocoque body 10, and extended backward in a vehicle. The standing part 34 is extending upward from the bottom 32. An engine 70 is directly attached to the rear surface of the standing part 34.
Abstract
(EN)
Abstract
Abstract
(EN)
